Hello all,
My question is about vacuum motors in parallel. I am using two of the same Ametek motors to power my home built flow bench that I am trying to use to measure airflow through a cylinder head. These motors come with a performance chart that I thought I could use to measure air flow in cfm.
The research that I have done lead me to believe that two motors in parallel will double the air flow for a given vacuum depression. My calibration efforts are indicating that this is false. I would like to understand why as well as how to estimate airflow if possible.
What I know is that the depression readings at zero to 1/2” orifice are accurate. A 2” orifice gives me a depression reading around 10” w.c. Instead of 4.4 as indicated on the performance chart.
Any help is appreciated. Please see photo attached.
Thank you,
Wes
Thank you,
Wes
