Mark Suplee
- Dec 17, 2019
- 9
I am trying to size a Vacuum Relief Valve for a Chemical Storage Tank at atmospheric pressure. I have looked through API 2000 but have only found specifications for selecting flow rate, nothing to do with pressure setting. From the Emerson Pressure Relief Valve Engineering Handbook, all I am seeing is that the valve should be set at a pressure lower than the tank design pressure.
Is it really as simple as that? If the tank is designed to withstand 10 psi do I simply set it at ... say 8 psi with a flow rate of 60 SCFH(per API 2000)?
Thank you
Thank you
