altoid3000
We are having some trouble placing vacuum ring on a tower. We are using ASME Section VIII Div 1. We looked in appendix 1-8C, 1-8E and found that the max distance of the centroid of the vacuum ring from the center of the seam weld is 0.84". Since it is RT-1 radiography, we got to radiograph the seam welds. But if we put the ring at 0.84", that does not give us enough clearance to push the X ray film (Source is inside the vessel, film outside)
We are thinking of redesigning the ring (may be I section) to keep centroid at 0.84" but the edge for welding far way from the seam weld. Has any one done this before ? Have anyone run into similar problem before?
