SudoHalt
- Mar 23, 2020
- 4
I am trying to determine the vacuum ejector flow rate I need to carry a Gypsum block of 30kg. Based on my calculations for pressure and force, I was able to obtain a configuration of 4 suction cups, each one being 8cm in diameter.
I am planning to use one vacuum ejector per cup. We have a compressed air supply that can supply up to 1MPa (10bar).
The following document seems to give an example of calculations, including the appropriate cup height:
To save your time, jump in to page 4. There is the table labeled: "Required suction rate as a function of the suction pad diameter". It basically recommends 12.7 liters/minute of flow rate for my configurations as I am planning 1 cup per ejector.
But based on what calculations are these suggested values obtained in the first place?
