hemiv
- Dec 7, 2018
- 78
I'm working on a repair detail for a 2-ply 2x12 valley rafter in an approx. 130 yr old story building. The rafter is undersized and each ply is split at some knots near the mid span.
I think the best thing to do would be to replace or sister it, but that would require temporarily supporting the 2x10 jack rafters. The attic floor framing is unknown, but its span is pretty large and the slate roof is pretty heavy. I think shoring may require posts to go through the two floors and basement below.
The owner's rep wants to look at an option that doesn't include resupport of the jack rafters. I have an idea to run a channel toe down along the bottom of the valley rafter and connect it to the sides between each jack rafter via welded-on plate tabs and lag screws. The idea is to work like a beefed up flitch plate. My preliminary detail is attached.
I don't think I can get this to work as a composite member - the fasteners as shown will not develop horizontal shear as needed for composite behavior. Does anyone have another thought or a better approach?
