JohnsonMadukayil
- May 23, 2002
- 17
I am currently working on a Design Report for a Threaded Pressure Relief Valve for a Nuclear application. ASME Section III recommends the use of ANSI B16.34 for body min wall thickness and pressure rating calculations. Table 3 of B16.34 is used for the body wall. While Table 4 is to be used for the threaded end connection. While Table 3 is more amenable, Table 4 seems to be extremely conservative and bodies which might deem to be a class 150 or 300 according to Table 3, fail the Table 4 test.
Under what circumstances is Table 4 to be used? The threaded valve has the body end connection as male end with NPT threads. It is 1/2" NPS. The outside diameter to the root of the thread is 0.726" while the inside diameter of the bore is 0.500". This gives a end wall thickness of 0.082" while the minimum required according to Table 4 is 0.130". Can somebody please help throw some light on this?
