Bambie
- Mar 31, 2012
- 242
thread378-336794
I am looking for a recommendation for a laboratory that performs viscosity testing of valve packing sealants that are very viscous, require high pressures to flow and likely non-Newtonian.
The intent is to predict whether control valve response will change due to viscous drag from the sealant after being injected into the stuffing box through the packing leak-off line.
I have attached a proposed test procedure and analytical basis and would appreciate constructive comments on my approach.
