Pat, I guess I was too eager to ask burning questions after becoming a member (searching on keywords is a member-only feature). Anyway I have found enough info on accumulators in relation to turbo lag, thanks.
I would very much appreciate additional input on the subject of valvetrains though. I have always found the setup of a shaft with lobes, rockers and strong springs a strange one. In my way of (naive?) thinking there must be much more elegant and efficient ways of opening and closing valves in a particular order and with particular timing. I know of (radical) different mechanical setups that never made it and I guess the way to go eventually is an ECU controlled system of individual valves like they use in F1.
What do the experienced and professional members of this forum think of the classic valvetrain? Do you consider it quite OK or is it just something that has historically grown on us and thus live with?
I also have a less philosofical question: if valve float wasn’t an issue would it be possible to gain more usable power from a typical automotive engine and would this be something engine designers/builders would be interested in?
I really appreciate your input,
Jochen
Jochen
