vane flow anemometer vs airflow chamber (flow bench)
An airflow chamber should be more accurate IF it's properly calibrated.
If you're seeing >10% difference between the chamber and flow hood, it may be your setup. Are you accounting for the additional pressure drop caused by the flow hood?
ko (
