Ravind5
Industrial
- Feb 11, 2023
- 1
Dear All, Greetings,
I am facing a challenge with a pipeline system that is experiencing pressure drop at a certain point.I am looking for suggestions on how to improve the flow and reduce this pressure drop. As an engineer,I am interested in knowing the best practices and methods that can be used to solve this issue.
We are receiving LPG MIX from A point (2.5KM away) through straight 8" Liquid pipeline and 6" vapor pipeline and meets at mid point controlled by MOV's and goes through a few bends, After the midpoint, the flow goes through a another 1.9KM long pipeline to point B spheres. After completion of liquid, we need to clear the liquid line of vapor pushing and this is where the problem starts as vapor pressure doesn't have a strong flow to push the liquids from the midpoint to the spheres. This is due to compressor used at point A was not designed for vapor pushing.
Please share your thoughts and experiences in this matter, as I would greatly appreciate any insights or recommendations on the best course of action to take.
Thank you
Thank you
