Saumian:
As I stated before: a vapor return line (actually, it a vapor balance line) will not work with an “acid egg” or air pressure type of liquid transfer. We may be having understanding problems because of a language difference. I wish we could communicate with drawings and sketches because that is the most effective and positive way for engineers to communicate on this type of problem, but this is not possible on this forum.
Aqua Ammonia is a mixture of water and NH3 gas to the point of saturation. The gas is dissolved in the water and will escape when the pressure on it is reduced. This is not a pure, saturated liquid – such as pure liquid NH3 or LPG – and it will lose its NH3 content as you pull a vacuum on it. It no longer is Aqua Ammonia if you continue. That’s why I don’t recommend the air compressor type of transfer system for your operation. I think I was pretty explicit about it. For example, I give 5 strong reasons for recommending what I do and I also state why pumps would be just as readily available. Putting a vacuum breaker in your Fresh tank and sucking with the air compressor doesn’t improve the operation other than protect the Fresh tank. You still have the build-up of NH3 vapors and its problem to the personnel. I would never use nor recommend the gas/vapor type of liquid transfer unless TOTAL, SAFE containment is ensured. That, the 5 reasons, and the fact that a tanker truck pump is feasible are the points that I emphasize as leading to the logical use of a pump instead of an air compressor. Of course, the pump system should have a balance vapor line.
The best and simplest manner of resolving the problem (exposing operating personnel to NH3 vapors and pulling a vacuum on atmospheric vessels) is to use a cast iron, conventional, centrifugal pump with a vapor balance line to transfer Aqua Ammonia. I have been exposed to NH3 vapors and I have seen the effects of severe exposure to the same. It is a painful and needless experience and I can’t blame your operators for leaving the building! The terrible damage and pain that NH3 can inflict to the mucous membranes (like your eyes, mouth, nose, etc.) is defined as a definite human hazard and should be avoided at all costs.
In 1976 I witnessed a tragedy here in Houston, Texas that involved the overturning and rupturing of an NH3 tanker truck on a Freeway overpass. Many motorists and other people were overcome by the resultant, toxic, and terrible NH3 vapors that blinded them and burned their bodies. It was horrible to see humans killed in this manner, with so much pain and no recourse for help. I have personally resolved to never allow this type of disaster again. It need not happen if one takes the time and controls to engineer around it.
Art Montemayor
Spring, TX
