I'm currently trying to put together a variable gain for volume control of a medical listening device (20-2kHz). The preamp is a low voltage op amp LM6582 wired in an inverting configuration -(Rf/Ri). The adiuo amplifier is a low voltage LM4860 1W essentialy an inverting configuration. The problem occurs when placing a pot in the feedback path. The signal is attenuated nicely until about 35% of the maximum value of the pot. The signal at 35% goes to the rail 3v. The feedback path will handle a nominal valued resistor that is equal to the maximum value of the pot, so the device is not near its maximum gain. These devices have not been wired together and remain seperatley tested until I get a nice volume control out of on or the other. I am looking to use these two devices for this solution. I may have to use a voltage divider of the electret microphone signal. Any thoughts sent my way would be helpful.
