Variable Fillets
Terminus0
74
Does any one if you can use a variable radius to not just change the fillet radius along the edge but to make the radius themselves non constant.
I mean have the distance the fillet extends be longer on one surface than the other?
So there is no command that can do this in Solidworks?
It is going to be extremely difficult to make this fillet by a sweep. I'd be pulling my hair out.
If a sweep will not work,
You can add a chamfer with different length legs, then you can add fillets to the chamfer?
Frank
