Im installing 2 Trane Screw Chillers with variable primary flow chilled water pumps on Variable speed drives (there is no secondary loop). The pumps are being controled by a Trane Summit Controller. Is it a good idea or not in a variable flow system to reset the CHW temperature for energy savings or is it too complex. I was thinking of resetting the temperature depending on AHU valve positionins once the chiller pumps are running at a minimum for say 10 minutes continuously. Any ideas??
