Variable Section Sweep
OMERYOUNOS
17
Hi
I want to cut around a solid base with variabe sections.I can do with constant section using command "cut-sweep".
can anyone help.
thanks.
omer
You could try using a sweep with guide curves. If you need to control the section at different points along a trajectory, use a loft.
Your terminology and previous posts suggest that you have experience with Pro/E. You could compare use of guide curves in a sweep to Pro/E's "variable section sweep". However, SW limits to two guide curves.
[bat]On justice and on friendship, there is no price, but there are established credit limits.[bat]
Can i cut in a base feature using loft command with variable sections.
thanks for replying.
Sure you can into the base feature using the loft command, I don't see why not.
You can't remove the entire base though, you have to leave something there.
Scott Baugh, CSWP [spin] [americanflag]
3DVision Technologies
faq731-376
When in doubt, always check the help
QUOTE:
<However, SW limits to two guide curves>
I am not aware of any such limitation. ASFIK, you can have an unlimited number of guide curves for a sweep. I just made one with 3 guide curves.
Sorry. My surface game is a bit rusty. Sweeps allow multiple guide curves, but for orientation control, one is restricted to using 1st or 2nd guide curves.
One thing I would like to see is a feature similar to Pro/E's variable section sweep.
[bat]Someday, someone may kill you with your own gun, but they should have to beat you to death with it because it is empty.[bat]
thanks buddies for all the help i will try it then let u know.
