variable sheet names in Journal
Lilu2Go
AT
Hello @all!
I created a journal for exporting cgm files and execute this with run_journal.exe. Now, I have a problem with the names of the drawingsheets... sometimes they called "BLATT", or "DRAWING", or "SHT1". I couldn't find a solution to get this part varible for more than one name.
Dim drawingSheet1 As Drawings.DrawingSheet = CType(workPart.DrawingSheets.FindObject("BLATT"), Drawings.DrawingSheet)
Has anybody an idea? Thanks a lot!
 http://files.engineering.com/getfile.aspx?folder=8112bc96-a31e-470e-8225-6a76dbe1733f&file=Orginal_cgm_export.vb
Use the parts drawing sheets collector instead of .FindObject()
Code:
For Each sheet As NXOpen.Drawings.DrawingSheet In workPart.DrawingSheets
    MsgBox(sheet.Name)
Next
ok, it took a while, but eventuelly I got it working! Thank you!!!!
