I am currently working on the design of a chemical injection skid for offshore use. We have designed the unit to run from a 400V 50Hz supply. There are two motors on this unit. These are coupled to geared pumps. My client has now stated that the unit should run from the following supplies:
400V 50Hz
400V 60Hz
450V 50Hz
450V 60Hz
The pumps cannot operate at the higher speed.
The motors are EExde, 55kW
Would a VSD overcome this operation by setting it so it always outputs 400V 50Hz? The on board PLC on the skids will provide a volt-free contact to start and stop the pump.
I have not used VSDs before so any advice would be most welcome
400V 50Hz
400V 60Hz
450V 50Hz
450V 60Hz
