VARIABLE TO RETAIN SLECTED SOLID
cfee
Industrial
Apr 22, 2002
491
Is there a variable to retain the subtracted solid object ? DELOBJ isn't it. THAT one only retains lines and curves used to define surface or solid objects.
I need to subtract the same component from a series of other components arranged along the one I want to retain. Making multiple copies of the object to retain is not a prefered approach, but its the one I use currently.
Thoughts ?
Thanks -
C. Fee
