KENAT
- Jun 12, 2006
- 18,387
I have a small motorized microscope stage design I'm working on.
In it we have a couple of different types of hardened stainless steel (440C or 440F) balls/ball ends on sapphire bearing.
One type in horizontal plane is a simple linear plain bearing where the ball end slides across the sapphire pad. An initial proof of concept (PoC) had a little trouble where one sapphire pad seemed to wear the matching ball end, but we believe this was due to some roughness on the sapphire - and the action of the ball wearing makes logical sense.
The other type is in vertical plain where ball tips of ball screws push against sapphire pad. These balls rotate when the screws are turning, they also slide when the stage is moving in the other axis or potentially could be turning and sliding at the same time if moving in both axis. On the PoC this worked fairly well over thousands of cycles. Some of the running was done dry and some was done with a little grease.
We've now built a full prototype of the stage and are having trouble with the vertical bearings. The balls/ball ends are chewing up the sapphires after just a small number of cycles - maybe a few hundred. This is with just the sliding motion - no simultaneous rotation element. These bearings are running dry as we can't really seal the stage and our customer base aren't good with preventive maintenance so we don't really want to have to use lubricant.
Initially when using custom ball ends we noticed they were rougher than we'd specified, they were replaced with off the shelf balls of smaller radii but we still see the problem.
My research has taught me that Sapphire is anisotropic in terms of hardness, but even in the 'soft' direction it should be twice as hard as the SST on Knoop scale. Surface finish may also be a contributor but we call out a 2 micro inch finish on the Sapphires and are buying from a company that makes jewel bearings as well as optical windows.
We did do a crude test of scratching sapphires from the original PoC and the new prototype with a carbide scribe. The new sapphires scratched fairly easily and cleanly while the old ones just kind of grazed slightly & required more force to do so.
Any thoughts on what might be going on and/or how or what we need to specify to correct it?
Thanks,
(I'm posting here as the bearing forum didn't look particularly active.)
Thanks,
