skeletron
- Jan 30, 2019
- 887
I'm wondering if there is a way to modify a Moment Distribution Method to account for a change in cross section. For example, a slab clear spans between 8' wide thickened bands over the support. I set up a moment distribution tool to handle multiple spans but I'm missing out on the accuracy of the thickened section between clear spans. Is there a way to hand calc or simplify the analysis through spreadsheet application? I think the obvious answer is "jump to the software," but as a curious mind and a novice concrete designer, I'd like to keep my *ahem* dignity before having to rely on the machine (but eventually I will turn to it...). I thought I could potentially modify my moment distribution spreadsheet to have stiffness factors at the support conditions that replicate the thickened band. I'm not sure if applying this is worth it or even accurate.
