mech4321
- Jun 8, 2009
- 15
I am wondering if VAV boxes minimum flow setting can be adjusted higher without rebalancing the min/max with a TAB contractor. For example, adjusting via the BAS the minimum flow from 25% to 35% to increase the outdoor air fraction in the spaces. The box sensor will be able to read the flow. An engineer came up with the necessity to appeal to a TAB contractor to rebalance the boxes in this case. Why?
