VBA/CATScript memory leak
peter_m
Automotive
NL
Hello Everyone
I have read that memory leak when running scripts in Catia is a "feature", but until now I didn't realize that it leaks like a sieve. Or maybe I'm doing something wrong.
I wrote a simple script to test this:
Code:
Sub CATMain()
	Dim oDocument As PartDocument
	Dim oPoint As HybridShapePointCoord
	Set oDocument = CATIA.ActiveDocument
	For i=0 To 10000
		Set oPoint = oDocument.Part.HybridShapeFactory.AddNewPointCoord(0, 0, 0)
		oDocument.Part.HybridShapeFactory.DeleteObjectForDatum oPoint
	Next
End Sub
Below screens from task manager before running script, after first run and the second:
CATDUA shows no errors, garbage collector should clean oDocument and oPoint at the end of the script, so where is the problem?
Peter
did you submit to DS as SR ?
Eric N.
Just realized I have same problem with one script...
I'll put a counter as global parameter (so it will stay in CATIA Session) and remind user to close session if counter reach some TBD value...if user keep working with leaking script I'll change background color to RED. Final step the script will simply close catia and wish user good night!
Who said scripting was not fun [bigsmile]
Eric N.
