VBA create chanfer by selected faces
TiagoFigueiredo
Industrial
May 22, 2013
503
I'm trying to create a chamfer using pre selected faces in a macro. But i'm no having much sucess
what I have tried:
The faces are previously selected.
Code:
chamfer2 = shapeFactory1.AddNewChamfer(reference1, catTangencyChamfer, catLengthAngleChamfer, catNoReverseChamfer, 1, 45.0#)
        Dim Num_Faces As Integer = selection1.count
        Dim Faces_ref(Num_Faces)
        For i = 1 To Num_Faces
            Dim MyBRepName = (selection1.Item(i).Value.Name)
            MyBRepName = Replace(MyBRepName, "Selection_", "")
            MyBRepName = Left(MyBRepName, InStrRev(MyBRepName, "));"))
            MyBRepName = MyBRepName + ");WithPermanentBody;WithoutBuildError;WithSelectingFeatureSupport;MFBRepVersion_CXR15)"
            MsgBox(MyBRepName)
            reference1 = Part1.CreateReferenceFromName(MyBRepName)
            chamfer1.AddElementToChamfer(reference1)
        Next
the error appears here:
Tiago Figueiredo
Tooling Engineer
Problem found...
Code:
            MsgBox(MyBRepName)
        Next
It should be
chamfer2.AddElementToChamfer(reference1)
Not Chamfer1...
I'm really becoming dyslexic...
Tiago Figueiredo
Tooling Engineer
I think the error messages are quite different in your case:
1. chamfer1 is not initialized (=nothing --> "Object required")
and
2. method .AddElementToChamfer fails.
Unless chamfer1 was already initialized :)
Calin
Unless chamfer1 was already initialized... that's why I was looking to the mistake...
Tiago Figueiredo
Tooling Engineer
