VBA modal / non modal
itsmyjob
2,375
Hi all,
I am doing some macro using VBA.
When I try to have a non modal userform and run the macro from VBA it s fine but when I use it directly under CATIA, I dont see it.. (if modal everything fine)
I use : UserForm1.Show
I use CATIA V5R9SP3
Have fun,
Eric
catiav5@softhome.net
Hi
The difference between a modal & modeless form is a modal form prevents further program execution untill the form has been dismissed.
With this in mind I suspect when you use a modeless form the form is shown but instantly buried by further execution of the program. When you use a modal form the program is halted leaving the form on top untill you have dismissed it.
Hope this helps
Pete
Further info on the wonderful world of vb can be obtained from many web sites (VBA is not very diffrent from VB) and the horses mouth at
