eeinpa
- Nov 12, 2006
- 65
We have a large planing mill which is in need of some upgrades. It originally had a DC motor driving a multi-speed gearbox. Overall gearbox transfer ratio is selected by a series of multiple-plate clutches built into the gearbox.
Originally I was hoping to eliminate the gearbox entirely, but duplicating its max torque AND speed range is really tough
The gear ratios vary from 9:1 to 360:1!
Instead, I am now thinking about using a vector-grade motor with vector VFD to drive the gearbox, and keeping the gearbox (with new shift actuators).
The catch is, we'd like to have simple positioning ability (really just a programmable stop/reverse point). Because of the clutches in the gearbox and the possibility of them slipping a bit, it would seem desirable to have a feedback encoder on the OUTPUT of the gearbox. But that means the motor's feedback device is going to turn anywhere from 1/9 to 1/360th the motor rpm! Worse yet, that ratio will vary when you change gears.
Anyway know of a vector VFD that will cope with this situation? I have not used vector mode much, and never with encoder feedback.
Or do I just put a PLC reading the gearbox output encoder, and delivering commands to the drive?
Useful suggestions appreciated.
