Carbof
- Jan 5, 2020
- 1
Dear all,
your kindly help is requested, we are designing a Vertical pump , service spent Caustic closed Drain transfer pump (Caustic concentration 20%), type of pump selected VS4, Capacity 10m3/h, Design Temperature -45/170 C, Operative Temp. 20 C, MWT 50 C, Design Pressure 5 barg, Operative Pressure 0,14 barg, MWP 1 barg, Material class S1 as per Table G1 of API 610;
Do you have suggestion for an alternative Material class selection or you confirm that material class selected is correct?
