Gopher13
- Jun 21, 2016
- 94
I have a question about a pretty common detail where I wish to transfer lateral diaphragm load into a wall but not gravity load. Please see the attached drawing. How do I assure the joist and angle will be able to move up/down without loading the wall? Do they not tighten the anchor very much so there is minimal clamping force to overcome? Should there be some sort of bond breaker between the vertical leg of the angle and the masonry or should I put a steel plate between the two at the anchor locations to decrease the friction? I have also seen details where there is teflon or graphite between two steel members at the slipping surface. Is this something that should be done?......so many question.
