Vertical text in labels or textboxes ?????????
energetika
5
0
0
MK
Hi all!
Please can somebody tells me how to put text vertical in labels or textboxes?
I tried to find it in helps but with no success.
Thanks in advance
Hi enertika,
You can create the text in a image editor software and insert a picture with the text.
It's a way.
I hope it can helps.
MHendler
Just be sure the TextBox and Label are set to allow several lines (Multiline=True for TextBox) (WordWrap=True for Label)and then use vbCrLf to change line like this:
Text1 = Text1 & vbCrLf
Label1 = Label1 & vbCrLf
cowski (or his link) has the right idea. The answer is to use the Windows API, which has text rotation functions.
MHendler's solution does not allow for the text changing.
The Wade/Gaba solution is a nasty kludge, and does not rotate the letters.
