Erdbau
Geotechnical
- Jan 19, 2008
- 86
We have an old (35+ yr) system that spins a cone gear at very slow speeds: input rotation needs to be as slow as about 2.5e-4 rpm, i.e. 4000 minutes per rev. The old system we had involved an AC synchronous motor running at 15 rpm, a 4:1 reducer, a multigear reducer (ranging from 2:1 to 1000:1, and a 16:1 reducer to the cone gear. The input torque on the cone gear needs to be about 100 in-lb. The manufacturer hasn't made the multigear reducer in over 20 years (pull and turn shifter). The multigear is malfunctioning (I think it is slipping, but we don't have the time or expertise to take apart and diagnose).
I have two questions: 1. Do these multigear reducers still exist, and if so, can anyone suggest manufacturers?
2. An alternate solution (need slow, constant rotation, and need to be able to repeat a speed (similar to the way I used to be able to when I set the dial to a particular gear ratio)) that I was thinking of was using a stepping motor, with the appropriate reducers to get to an acceptable torque. Would using microstepping to rotate the motor very slowly be a reasonable use of a stepping motor?
Any help would be appreciated. I am completely out of my element on this one.
