vessel re-rate
Sebra
6
I want to re-rate a vessel which is designed for 1.5 MPag @ 190degC. This vessel has another design criteria which is 50kPag @200degC which has been ignored during the design. to re-rate it, Should I only check the design for 50kPag@ 200degC or I need to rerate the vessel for 1.5MPag @ 190degC.
basically should I consider the highest pressure @highest temperature for vessel re-rating or only checking the vessel design for missing operating condition will suffice?
Thanks.
The best approach is to evaluate highest design pressure at maximum design temperature.
I find it difficult to believe that 10C difference at 190C will make much of a difference unless someone really got it too tight or that most processes can be controlled that accurately.
If it passes 1.5 @ 200C, then 50kpa @ 200C should be OK.
You really need to understand where this data comes from and how much spare has been added from max operating to design temps.
Thanks for your responses. If it was in design phase I would have design it to 1.5MPag @ 200degC in the first place but it is too late now. I personally think 1.5MPag @200degC is the best practice however wanted to know that checking the design for 50kPag@ 200deg would be sufficient as well or not. in other word is it a code requirement to design it to highest pressure at highest temperature? from you answers I undestarnd that it is enough to check the design for 50kPag @ 200degC.
Those are strange values for different design conditions. Is the 50kPa external pressure?
I have had to re-rate piping with a sliding scale of pressure based on monitoring UT thicknesses, but that wasn't at original design.
Perhaps it came from the PSV sizing? What service is this vessel in?
