Hello, I got a burn out motor winding due to mis-configuration of VFD setting. Yet, i could never find motor data setting on VFD for Voltage rating, however only percent voltage output (VFD) is available.
So i tried to play along this voltage output as well as frequency adjustment to coincide with the motor specs. I am not sure if this setting is correct with VFD at V/F mode controlled by pot, Please i need your comments.
VFD specs: 440V/60HZ, 3 Phase, Model: LG-iG5A
Motor specs: 400V/50HZ, 3 Phase.
"..the more, the merrier" Genghis Khan
