jimmy3456
Aerospace
- Dec 14, 2010
- 7
Basically I have a machine that has an open loop or v/hz type spindle drive. Has been installed for many years but just not happy with the performance. The drive just cannot respond to all the varying loads and bogs easily.
I have decided to install a difference drive with a feedback circuit. For this application, around 1% or so of rpm variance would be tolerable but load can vary quickly and motor needs to respond quick to keep spindle at speed.
Would todays sensorless systems be a decent solution or do I need true vectoring with an encoder? Will true vector really shine well above? My target is to get bad fast accel/decel rates as well as reasonable torque response for cutting loads for a machine tool.
Due to the high costs and this old machine, I would prefer a used drive for this. Because I do not need tight rpm control, a simple tach would probably do for the sensor but would a true vector system work with this or do they all need a true encoder?
