Dear all ,
The VGO Hydrotreater feed filteration system is facing problem of higher pressure drop , The feed is the mixture of Heavy vaccum gas oil,Light Vaccum gas oil and Heavy Coker Gas oil.The culpit is seen the quality of Heavy Coker Gas oil.Whenever, Coker unit,Ratio of HCGO Hot wash / Coker T'put is lower than 94 , the problem is more aggravated in Downstream VGOHT units which calls for very frequent filter stoppage , cleaning as well as some time reduction of VGOHT t'put also.
The correlation of VGOHT feed filter Delta P vz. Ratio of Coker Hot wash/Coker T'put is attached for your reference.
The constraint in the coker side is that higher ratio will call for reduction of Coker T'put as well.
PTQ forums says VGO Feed asphaltene should be less than 500 ppm which in this case it is 2 to 3 times measured and it is seen 500 ppm, ASTM D-1500 Color also remains <8 to ensure oil compatability and diene test.
Kindly give your expert openion to mitigate the problem.
