Help with these Issue.
about Vibration Analysis
See PDF attachement.
Thanks.
1 stage Pump
Fluid pump: Crude Oil.
Centrifugal Horizontal Pump
INGERSOLL DRESSER RAND
RPM: 3540 rpm
Type: 4HPX
Model: HPX
Serie: P-58106-02
Flow: 890 gpm /30514.27bd
Motor: Reliance
Potencia:250 hp
Amperaje:269 amps
Variables operativas actuales:
Suction pressure: 140 psi
Discharge pressure: 390 psi
SG: 0.77
Temperature: 300F
Flow: 408.33 GPM (14000bd)
Thanks.
1 stage Pump
RPM: 3540 rpm
Type: 4HPX
Model: HPX
Serie: P-58106-02
Motor: Reliance
Potencia:250 hp
Amperaje:269 amps
SG: 0.77
Temperature: 300F
