milkshakelake
- Jul 15, 2013
- 1,174
A client wants to monitor vibrations of the top floor of his building (7th) due to vibrations from adjacent construction. I've never done this before; I always monitor foundations, because that's where vibrations would start. Technically I could do it, and use non-construction times as a baseline to see what is caused by construction. However, I'm afraid that putting it so high up will weaken the link between vibrations and construction activity, because confounding factors like wind and mechanical equipment start getting involved. It might not be accepted if it's peer reviewed or lands in court if there are damages. I also wouldn't know the criteria; the code here (New York City) has a limit of 0.5 in/sec for alerting and 1.0 in/sec for stopping construction, but I've always assumed that's for foundations.
Is it okay to put vibration monitoring this high up for monitoring adjacent construction? And does anyone have general resources about where to put vibration monitoring?
