Here is another solution, its called stage-eight locking devices. It has a positive locking system that should resist all vibration.
Naturally, any bolted joint can lose some preload from thermal cycling, vibration, gasket/joint relaxation. To prevent these factors from affecting the fastener pre-load, do the following:
- Make the length of the bolt between the nut and bolthead, which is actually under tension, as long as possible. This increases the elasticity of the bolted joint, which makes the fastener act like a very stiff rubber band which can resist vibration and thermal loosening (you mentioned that these are in a foundry).
- Load all fasteners to 75% of their proof load.
- Minimize the number of surfaces in a joint. For example, if your bolt rests on a washer, and on the other side of the flange, the nut is also resting on a washer, then you have a total of five surfaces sandwiched in your joint; the bolt head to washer-> the washer to flange-> the flange to flange-> the flange to washer-> and the washer to nut surface. Solution: Purchase what are called flanged bolts, and flanged nuts(these are standard fasteners). These have a built-in washer integral with the bolthead and nut. Result: Only three surfaces remain, which increases joint integrity, since there are less surfaces to slip/imbed.
- Increase fastener diameter to the maximum possible, as this allows a greater preload.
- Eliminate all non-metallic gaskets in the joint(if any), and if necessary, apply O-rings or soft metal gaskets instead. This allows a metal to metal joint, which greatly resists loosening as compared to a gasketed joint with pliable gaskets.
- If separate washers must be used, these should be of hardened steel, and have a minimum thickness of 3/16 inch, for fasteners below 1.0 inch diameter. For fasteners of greater size than this, the minimum washer thickness should be 5/16 inch.The washer diameter should be at least 2x fastener diameter.
- The fastener outer diameter,should, as much as possible, be fitted snugly into the joint hole, if the main problem is vibration.
-Increase the thread engagement, by using nuts with a height at least equal to 1.5 x fastener OD. The increased threads spread out the preload more evenly, which reduces the internal thread deflection, thus maintaing more thread surface area under load. The same applies for blind threaded holes.
- Confirm the flatness of all joint surfaces to be joined. Nonflat surfaces introduce bending loads in the fasteners, and reduce the actual forces holding the joint together. Same thing goes for the surface quality of the joint surfaces; rough surfaces allow embedment, which produces a loss of preload. Misaligned flanges are another bad actor application.
- When torquing, apply antiseize under the surface of the nut or bolt head , including the threads. This increases the amount of bolt torque which actually ends up as pre-load; otherwise much of the torque will be lost in friction. If there is a vibration problem ==> do not torque with anti-seize or oils, only use locktite style adhesives, as these will act as a thread lubricant, and give chemical bond locking afterwards.
Abdul
