Vibration standard suitable for an ABS module circuit board
murpia
130
Is anyone aware of a public-domain vibration standard suitable for a circuit board of the type that might be housed within an ABS module?
Something the board could be submitted to, to validate the mechanical integrity.
Thanks, Ian
I can't answer your question but since the ABS module is bolted to the firewall typically, the environment is pretty benign for vibration apart from the vibrations cause by the ABS itself, which hopefully you have a handle on.
Cheers
Greg Locock
It might be more severe to look at the shock load delivered to the car body from a minor collision than to look at the vibration amplitudes from the road and engine.
Maybe Bosch has some info published for their products.
The OP referred to "validate the mechanical integrity" which is the ESS test that MIL-HDBK-2164A deals with. The ESS is a test that's supposed to weed out infant mortality and workmanship failures, and is therefore a very short and minimal-life-consuming test.
The link I posted addressed the possibility of reducing the ESS test time, while increasing the success rate for finding latent failures.
TTFN (ta ta for now)
