Views from 3D
Jegsaran
Automotive
Dec 16, 2020
42
Hello Everyone,
I'm trying to import an annotated view from a product to a drawing.
I have did some workaround using CATIA.StartCommand.
Here is my code
Code:
Set drawingSheets1 = drawingDocument1.Sheets
Set drawingSheet1 = drawingSheets1.ActiveSheet
Set drawingViews1 = drawingSheet1.Views
CATIA.StartCommand "View from 3D"
Set oParentDoc = CATIA.Documents.Item("DC-SectionCut-TemplateDoc.CATProduct")
oParentDoc.Activate
Set ActDoc = CATIA.ActiveDocument
Set Sel2 = ActDoc.Selection
Sel2.Search "Name=*Section Cut View1*,all"
Post this CATIA is asking me to click on the screen.
Since the view is not generated using traditional method I can't use drawingViewGenerativeBehavior1.Update also.
I tried CATIA.StartCommand "Select" but it is not working appropriately. Is there any workaround to click on the screen?
Thanks for sharing this LWolf. Both the links is about creating Isometric view.
All I need is to import an Annotation(TPS) Section Cut View which is already created in the product.
When I import it into Drawing it'll come as Section Cut.
The main theme here is to eradicate creating Front View to create section cut.
Did some workaround it is working now,
Code:
    oParentDoc.Activate
    Sel2.Search "Name=*" & IndivAssySecCut(i) & "*,all"
    inputObjectType(0) = "AnyObject"
    Status = oSel.SelectElement2(inputObjectType, "Click Screen & Select a Sheet", False)[indent]'asked the user to select the sheet from tree[/indent]
    DoEvents
