Violation of Laws of Thermodynamics required by Massachusetts Department of Energy Resources (DOER), 6
MJCronin
5,096
ONLY FROM THE PEOPLES REPUBLIC OF MASSACHUSETTS ! !
After several years of development, the builders of a much desired biomass power plant have finally given up.
(Biomass power plants, you may recall, are carbon "neutral"..... no "new" CO2 is considered to be released to the atmosphere)
The plant design was subject to the ever escalating environmental requirements of MASS DOER
The "cream on the cake" is the requirement by the fat ladies with flowered skirts, to violate laws of physics
DOER finalized restrictions in August that require all woody biomass plants to generate power at a minimum 50 percent efficiency in order to receive one half of a renewable energy credit (REC), and 60 percent efficiency to receive one full REC, up from the previous 25 percent efficiency standard. The restrictions also include regular Forest Impact Assessments, which are used ensure preservation by determining the biomass industry’s influence on the environment, and power plants much achieve a 50 percent reduction in lifecycle emissions over 20 years.
Now, these are the same people who hate all coal fired generation, nuclear power plants and gas fired power.....
Read the following:
also
Comments ???......... anyone out there study Thermodynamics ???
MJCronin
Sr. Process Engineer
Venture Engineering & Construction
I'm not really familiar with this paraphrasing of the laws of thermodynamics but #3 does not make sense. More logical would be "Things will only get worse."
Do you mean a group of people who can make decisions without any facts about the matter? Smile big and talk good and you could be one of them.
I'm in the middle of writing a report on pneumatic controllers to try to counter the stupidity of these people. There is a class of controllers that I call "intermittent vent" that only allow gas to go to the atmosphere at the end of an actuation cycle. They vent a bit of gas for a couple of seconds, and then don't release any gas for (sometimes) days. The contractors hired by the regulators measured the exhaust from these devices during an activation cycle, timed it from onset to termination (around a second) and then divided the [low] volume by the [tiny] time and got a HUGE amount of gas emitted--two orders of magnitude greater than the continuous-bleed controllers that do release considerable gas.
In actuality these intermittent vent controllers emit 1-2 orders of magnitude LESS gas than the continuous bleed controllers. So in Colorado today, they are reviewing a new regulation that makes intermittent vent controllers illegal and requires continuous bleed controllers--the real result will be to require replacing 80-90% of the controllers currently in place (upwards of a million units) and putting 10-200 times as much gas into the atmosphere.
I think the problem is that anyone with any technical ability at all will run from government service. Further, anyone with marginal technical ability, but zero ethics or integrity runs toward government contracts. People with technical ability, ethics, and integrity do not deign to get their hands dirty in this arena (I know that I for one would rather work in fast food or loan sharking than take a government contract). It is hard enough for me to take jobs with industry associations.
David Simpson, PE
MuleShoe Engineering
Law is the common force organized to act as an obstacle of injustice Frédéric Bastiat
Cranky.....
I am not now, nor will I ever attend a school where I will be awarded an MBA......
MJCronin
Who said anything about an MBA? I was talking about political office.
David, godspeed you in dealing with that issue. It would be criminal to see a regulation put in place which results in such a dramatic increase in the amount of methane being emitted to the atmosphere, requiring all that cost and work and hazard, because some dumb@ss didn't understand what they were doing.
David, I had a professor at University who often had a nontraditional approach to problem solving. The problems he encountered in industry were not technical in nature, but personnel related. I think the answer in your situation is not to try to convince legislators of the right approach from a technical basis. I have seen that rarely works. However, campaign contributions from any of the manufacturers of the "intermittent vents" to key legislators has a high probability of success, at least for the short term. After that, it may be possible to get a revision of the report issued based on a criteria which puts both technologies on an equal playing field. Such criteria could monitor the gas vented for 28 calendar days and compare the technologies. After that, it is possible that the wording of this proposed legislation could be reversed to require the intermittent vent technology.
