VISCOPLASTIC LAW - Norton Hoff - ABAQUS ?
Lemine
45
Hello Engineer's,
I'm having trouble to set the dissipation potentiel of Norton Hoff below (cf.Image) to model the viscoplastic reponse of structure in Abaqus.
I want to know if programming UMAT It is the only way to overcome this problem?
Thanks in advence for your help
Have you checked the documentation? See at help.3ds.com
Reference Library > Abaqus > Materials > Inelastic Mechanical Properties > Metal plasticity > Two-layer viscoplasticity
But if the implemented method is not sufficient for you, then there is no other option than a UMAT to implement your own theory.
Thanks a lot dear Mustaine for your reply.
Is it possible to determine the parameters of two-layer viscoplasticity model in Abaqus (A,n,m,f) from the expression of dissipation potential ?
If the umat is the only solution I would be so thankfull if you can share a Umat exemple near to my case.
Thanks a lot,
There's also a CREEP subroutine that can be used for used-defined creep laws but if its capabilities are not sufficient for your goals then you need full UMAT.
