YoungTurk
- Jul 16, 2004
- 333
I need to estimate the pressure needed to force a high viscocity fluid from a container (55 gallon drum/barrel) at a given flow rate (<=1gpm). I'm thinking I'll have a 2" hole for out flow in a follower plate, which is where the pressure is applied. Unfortunately, I don't know the fluid viscocity, and I can only get a quantity of about 1 quart to experiment with before the prototype stage, when I'll be able to try it out with either 1 or 5 gallon containers. It's way too thick for a Zahn cup-type measurement, the material being similar to Bondo fairing compound in autobody applications (like thick mud). Any ideas of how I can get a rough idea of the pressure needed?? With those numbers I could get started on the rough design, and verify flow rates in the prototype stage.
