Visible in view settings get changed when new sheet is added
ShirleyB463
21
We are having this problem, when is the next release of NX 7.5 going to come out? This is a real pain to redo views, because you add a new sheet.
Solution Center
Previous Doc Next Doc
Subject: [PR-01832409] Visible in view settings get changed when new sheet is added
Description of Problem:
IR Number: 1832409
Priority: 1
GTAC Urgency: No
PR Matrix: 6a,b
Problem Description: Visible in View layer filter is changed for one view on an existing draft sheet when a new sheet is added.
NX Versions: NX v7.5.3.3
Managed Mode: No
Tc Versions: N/A
Containing:
Part: 001555.prt
AVI: Layer_Visible_In_View.avi
Syslog: syslog.txt
Other Files: N/A
Work Around: N/A
Steps to Duplicate:
Please view the avi for reference.
- Open the drawing 01555.prt
- Check the Layer Visible in View settings
- Insert a new sheet using a template
- Make Sheet 1 Work Sheet
- It seems like the first base view in the list (or the first placed base
view) loses the Layer Visible in View settings. The settings are not reset to
Global, if that was so all layers would be visible.
Traceback:
N/A
Problem is part specific: Unknown
Problem is OS specific: No
Platform Information-
Problem is platform specific: No
Platform:
Problem verified on the following platforms and OS versions:
Intel Xeon, Win7 x64
***** <<<<< This PR has been closed. The resolution was: >>>>> *****
Siemens PLM believes that the problem you reported where Visible in View layer filter is changed for one view on an existing draft sheet when a new sheet is added will be resolved by code changes made to the upcoming release of our software NX7.5.4.
PR Number : 1832409
Date Opened: 10-mar-2011
Status : FN
Priority : 1
Family : NX
Application: DRAFTING
Function : DRAWING/VIEW
Category : FUNCTIONALITY
Release : V7.5.2
Platform : INTEL
OS : WINDOW
OS Version : XP32_SP3
Terminal : OTHER
Platform specific: Undetermined
-- End of document --
Dear ShirleyB,
NX 7.5.4.4 is already available on the Siemens Download page.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Thanks, that page was alittle confusing to me, but I did find it.
