Vismockup Navigator zoom / scale ? 1
Tetragrammaton
Aerospace
Nov 27, 2002
85
Hi All,
I use Vismockup quite a lot.
One thing I have not found is a way to increase the size of the image in the Navigator.
Does anyone know if this is even possible?
It would be of great help.
Best Regards
Tetragrammaton :)
What image ?
The static preview in the ( default) bottom ?
Have you tried right click "Allow docking" ?
Tomas
My typical default layout is the main graphic window with 2 docked windows on the left
The upper left hand docked window is the Part Navigator.
Below this is the Navigator window as it is called in Vismockup.
I am, as I said, trying to understand if I can increase (or zoom) this image in the Navigator.
Alternatively change the resolution (mine is quite low resolution) though I expect this can't be done.
As for your reference to 'static' image = No, this image moves and update.
As for your comment, try right click Allow Docking? (I am not asking to dock anything)
Pls read my original post above to follow what I am asking, thanks.
Best Regards
Tetragrammaton :)
The purpose of that navigator is to zoom / pan the main graphics, not really for showing the details of the viewed object.
I have seen no option to zoom that window.( If you could zoom such that only a small detail was visible, it would counter the original purpose, to aid zoom both in and out.)
If you undock, you can make that window larger, and thereby get a larger image.
Tomas
HI
I just want to know that is there any optional product or similar product like teamcenter Visualisation mockup.
i want to know that what is that product and which company is that of , is that PTC or Dassault.
Just help me out that is there any product like Vismockup or any option for Vismockup with same features in that.
thanks
Bipin
+91-8979884421
As for an optional product, that is not a possibility to use (nor of interest) since this is the clients corporate system, hence not subject to change.
No, not PTC or Dassault, Teamcenter Visualization is part of the Siemens product range.
SIEMENS: Teamcenter Visualization 11
Best Regards
Tetragrammaton :)
