Schambach
- Jul 31, 2001
- 31
I use the VA software for frame analysis and I get along pretty good. When it comes to modeling plates I struggle a bit. I'm curious if there are any users out there that would be willing and open to having dialogue and answering questions off-line and ideally be able to learn from each other. If not, I'm curious about the following:
I'm creating a bolted connection between two beams. For various reasons I need to place a 3" square piece of steel at the intersection of the flange and web (both sides of the web at each flange......so a 4-bolted connection) such that I can connect to another beam end-to-end. I will gusset the "free" side of that plate such that from a modeling perspective I have a 3-side fixed connection of a 3" x 3" plate. I am going to use a 1" diameter A325 bolt to resist around 30kips in tension.
When I model this plate and break it up into really small elements I'm showing stresses that are really high around the supported perimeter obviously. However, if I look at the stresses that are on the plate a mere 1/4" away from the very edge I find that I could make a 3/4" A36 plate work. If not, and I only use the stresses at the very edge I would need like a 1" thick plate!
My gut tells me that 3/4" plate should be fine, but I don't know what kind of latitude or engineering judgment that I can apply to ignore the stresses at the very edge and utilize stresses that are 1/4" from the edge.......or 1/2"......or whatever makes good engineering sense.
Can anybody provide some perspective on how to read the results of my output and apply it to my design in a reasonable way?
Thank you!
Thank you!
