Visual Studio-'Let' and 'Set' assignment statements are no longer supported
Aleks_TS
IT
Hi all
I have an error in Visual Studio that "Set" and "Let" commands are no longer supported. Does anyone know which command I should use?
Here is one small example of the code in VB and what would be the code in Visual Studio?
Sub CATMain()
Dim partDocument1 As PartDocument
Set partDocument1 = CATIA.ActiveDocument
Dim part1 As Part
Set part1 = partDocument1.Part
Dim hybridBodies1 As HybridBodies
Set hybridBodies1 = part1.HybridBodies
Dim hybridBody1 As HybridBody
Set hybridBody1 = hybridBodies1.Add()
part1.UpdateObject hybridBody1
End Sub
JohnFx said:
Yes. In the old days you had to distinguish between assignment of objects and scalar types. Now everything is pretty much an object so they dumped the set keyword completely. I'm actually surprised they didn't leave it and have the compiler ignore it so the old code would compile without the change.
From other comments on that page it appears that Set is still used, just for some special cases.
