vandede427
- Aug 13, 2008
- 344
I'm designing a building that is on a site with expansive clay soil. Deep foundations (drilled shafts) and grade beams will support a structural slab at the ground level. I've looked at several different products for this application; the more typical "cardboard" type and the "rainy day" metal type for grade beams and slabs.
What I'm looking for is whether or not void forms completely degrade and absorb all the soil swelling pressure or if they still transmit some of the upward swelling pressure. I can't find this information on any of the products' websites.
The geotechnical report for this site says that swelling pressures could be as high as 2000 psf if no void form is used. It recommends void forms to help "reduce uplift forces" but it doesn't say what that reduced force will be. I understand it probably differs based on each product, but I can't find that info.
