ajk1
- Apr 22, 2011
- 1,791
Where suspended floor is to be temporarily supported by shoring (post shores) which is supported on old existing slab-on-grade, is it the practice to check that the slab-on-grade has no voids under it?
If so, how is this checked?
If it is not the practice to check for voids under slab-on-grade, how can such practice be justified?
We have found significant voids using GPR, and confirmed by drilled cores, that there are areas where there is up to 4" void under slab-on-grade.
There may be more questions to follow, depending on what answers I get for the above.
