Volt-VAR optimization
budhiman
60
Hello All,
I'm studying on this topic of Volt-VAR optimization for a project which I'll be working on. I was wondering if people could advise on good reference material and any reports/presentation which they could share. Especially if we have certain set of data which has the load based on the VVO activated on the system. How can this data be used to understand its benefits. I ask this question because the load is dynamic if using load tap changer is one mode for Volt-VAR optimization. When the voltage is dropped (lower the load tap) at the transformer the MW does go down but for a small interval and starts rising it doe snot stay constant.So how to interpret if the VOO is providing any benefit or not.
