volume difference
abranda
Hi everyone,
I am using ANSYS Workbench and when I go from Design Modeler to Mechanical I found different volume values for some body. For example, the volume is 0.1407m^3 in Design Modeler but it go to 3.59m^3 in Mechanical. Therefore, I found a wrong mass...
Do you have an idea to fix this problem?
Have a nice day,
Mric
 http://files.engineering.com/getfile.aspx?folder=f653db62-01b7-40ff-ae65-e2392cbcf258&file=volume.jpg
more info:
- I am using the same units
- I did not have the same centroid between Design Modeler and Mechanical
Thank you for your help
