Once again, a premium and classic thread is born.
I cannot help but re-inforce what 25362 has shared with us: the hydraulic pressure (force) CAN be estimated by using his clever and unique method. (This technique should clearly be an FAQ!) I can't help but give 25362 a well deserved star (he deserves mine). Although he has mentioned this calculation method in past threads, it seems few people have given it the recognition it deserves.
Doug has beaten me to the punch again. I forgot all about the terrible potential of ball and plug valves to form their own, inherent blocked flow when I wrote my response. This is a feature that should be noticed, studied, and submitted to instant memory by every engineer working with saturated liquids - especially the liquified gases (which are usually all in the saturated state). The characteristic that Doug describes was "discovered" in the mid-60's, shortly after ball valves became the rage and were employed in liquified gas service. I must have replaced dozens of Teflon seat rings before it dawned on me (& others) that something was not going right. Worcester Ball Valves caught it and started recommending a 1/8" hole be drilled normal to the flow in the valve. The upstream face of the closed position was always used by me to furnish this relief feature. Some ball valve manufacturers even went to furnishing another, smaller drain valve on the main ball valve's side to drain the cavity's inventory. This latter method was a knee jerk reaction to what was suddenly perceived as a potential hazard. I haven't seen this type of solution recently. The application of a standard (non-self venting) ball valve in liquified gas service is rightfully considered a potential hazard - although few, in-experienced engineers would spot it. Doug is to be congratulated with a star also for pointing this important point out. The same applies to plug valves as well - although these are seldom considered for liquified gas service in today's applications.
These two guys have made this thread into a classic and one to be referred to in the future. Thanks guys.
